It will work but I have been told it could do alot of damage. It will work because the 8 cylinder bearing is larger than the 4 cylinder shaft so it will go in no problem. What you should do and it is also what I have done in the past is change the pilot bearing to match the trans you have. 4 cyl tranny = 4 cylinder pilot bearing, 8 cylinder tranny= 8 cylinder pilot bearing.
