Adam, yes, straight 1995 gt sn95 conversion. Front and rear disks, master cylinder and kept 91 booster. I did lose the factory prop valve and built my own under the mc with adj prop valve and a line lock.
Thanks flava!
By pedal being lower, are you saying the stroke is long? In other words, you are finding the pedal going down pretty far to get good brake modulation?
Nope, brake modulation is fine. Its travel is nearly identical to before, its just sits lower than before at rest. AKA, not as high as it was before.
Do they make an 1 1/16" thatll bolt into a fox?
