Reddevil91
- Mar 3, 2010
- 1,612
- 795
- 163
What where????Theres abandoned projects all over the interwebz. I just saw a disassembled 347 for sale.
Different places. This was on my local fox page.What where????
It’s the way to do it. It’s how I done it ( except I only had two ends to worry about.) For a Ford banger it’s absolutely necessary as the stock piston is over .100 down in the hole. I did mine w/o the rings on the pistons and measured the piston at the point directly above, and along the same line that the pin was below.So the machine shop I dropped the block off at says I need to do the old school method of measuring the 4 corners of the block with the outer 4 pistons installed.... this is to do the zero decking of the block.... is this how it's done normally? I like this shop and the owner is fair how do I do this without screwing it up?
Good to know thanks Mike, now should i use a set of feeler gauges or is there a way to do this with a dial indicator?It’s the way to do it. It’s how I done it ( except I only had two ends to worry about.) For a Ford banger it’s absolutely necessary as the stock piston is over .100 down in the hole. I did mine w/o the rings on the pistons and measured the piston at the point directly above, and along the same line that the pin was below.
Why make it harder than it has to be? A straight edge across the deck, and a feeler gauge to determine how much has to be cut off.Good to know thanks Mike, now should i use a set of feeler gauges or is there a way to do this with a dial indicator?
