- Mar 7, 2002
- 9,441
- 5,395
- 224
I just pulled the trigger on a late-model Prius booster/master assembly for $61.10 shipped, so we'll see if it can be made to fit.Well then. Leg day is back on the menu boys!
Maybe not. Sorry I cannot let this go just yet. lol
I am not certain but it looks like a 2016 to 2019 Prius has electric power brakes. It is about the size of a hydroboost slave and appears to be an all in one unit. The electronics hang off to the drivers side so it appears it may fit. I am finding them for between $100 to $700. Used should be fine. I imagine they are fairly robust.
Will take some more research but if it's not computer controlled it appears to be an option. Even if it uses higher voltages a water proof buck converter will probably be okay with a decent alternator. A capacitor may be enough to overcome voltage surges on a stock alternator since the motor doesn't run constantly. An arduino may even be an option for control if it needs a computer.
