Meh...I'm gonna have to pass on the 12 pipes sticking out of the hood thing Dean..If I was gonna do that, I may as well consider the machine gun thing too.
In this life, neither will happen. Although I do appreciate your comments.
Today, The plan will be to build, position, and plumb the vacuum reservoir. Lets think of that as the Monster's external Iron lung.
It looks to me like I may, or more likely, may not be able to run the engine in speed density. That being determined solely because of the lack of a common plenum post throttle body for the ECU to try and figure out what the engine is doing.
If I lose Speed density, that'll means I lose the MAP sensor's benefit...determining for me whether or not I'm at idle, accelerating, cruising, or decelerating, whether or not the engine is under load, and adjusting timing and fuel to account for that. I lose EGO correction,...the corroboration to the map sensor that I need more or less fuel...effectively making the O2 sensor worthless. I lose the self tuning feature of Tunerstudio.............I may as well have put 3 Webers on the thing because, in effect I have went backwards. I can now only adjust fuel based on throttle position. The car will probably be tuned Alpha N.
Now I'm still gonna build the iron lung (Actually made out of steel), cause I'm hoping that I still have a prayer in hell of being able to use that as a remote plenum, and commensurately be able to run the engine in Speed density. The engine will be plumbed to it through 6 individual vacuum lines, coming from each of the throttle bodies. The brakes need vacuum still, as does the transmission. I also need a place to plumb my FIDLE valve to show the engine a vacuum leak at cold start, so that it'll run faster. I need to have a place to plumb my MAP sensor to. How big that thing needs to be is the question.
That means that I'm going down town to get push connectors for all of the lines that I'm getting ready to plumb.
That means that I'm not messing with and finishing the exhaust today...( It's the way everything is done with me...get to 90%,..move onto something thats at 0%, till you still have 100% of the build left in front of you in (10) 10% chunks.)
Besides....It'll give you guys a new set of pictures to look at this afternoon.
