Well guys, I think this is the 3rd thread I've started about my engine ticking. Here is a link to the last one - http://forums.stangnet.com/showthread.php?t=540063&highlight=lifter
I'm not sure what else to do. I replaced the pushrods with new 6.272" FRPP ones thinking that might be the problem since my old ones measured about 6.250 (not bent). Still ticks. Tried to isolate it more with a stethescope, found a few that seemed SLIGHTLY louder than the rest, and had 0.010" machined from those pedestals. Still ticks. I checked for side to side play of the roller rockers while the engine is running, and it checks out OK, they all had about .008-.010" side play, which I consider normal (heck they are retained by snap rings). I checked out the header gaskets, they look fine (because they are brand new) and all bolts are tight. Collector and H-pipe bolts are tight. It seems really strange because even with the stethescope I cannot pinpoint the noise. It is most noticeable at about 2000 rpm, while deccelerating. Its f-ing loud though, I can hear it at 60 MPH. The car runs perfectly. This engine has 56,000 miles on it, and the heads are new Thumper ported E7's. The cam is a Comp 270HR, with FRPP 1.6 roller rockers. This combination of parts made NO valvetrain noise before I put the new heads on. I also have the dual valve springs on the new heads (cam has 0.533" gross lift). Is one of my lifters begging for mercy under the new springs? I really appreciate the advice you guys have given me in the previous threads. I built this f-ing thing, and i'm not going to let it win!
