A ace305 Active Member Dec 28, 2011 171 21 28 Aug 18, 2018 #1 Aug 18, 2018 #1 is there an amp under the head unit?
Neuron 5 Year Member Nov 6, 2016 859 199 93 Aug 19, 2018 #2 Aug 19, 2018 #2 The first amp is actually contained within the head unit and runs all four tweeters. Great Thread above here on this:https://www.stangnet.com/mustang-fo...eplacing-your-2001-mach-460-head-unit.482713/
A ace305 Active Member Dec 28, 2011 171 21 28 Aug 19, 2018 #3 Aug 19, 2018 #3 Neuron said: The first amp is actually contained within the head unit and runs all four tweeters. Great Thread above here on this:https://www.stangnet.com/mustang-fo...eplacing-your-2001-mach-460-head-unit.482713/ Click to expand... thank you. this has driven me insane. only the tweeters work. no door or rear. I have tested amps, fuses etc. I'm out of options
A ace305 Active Member Dec 28, 2011 171 21 28 Aug 20, 2018 #4 Aug 20, 2018 #4 Neuron said: The first amp is actually contained within the head unit and runs all four tweeters. Great Thread above here on this:https://www.stangnet.com/mustang-fo...eplacing-your-2001-mach-460-head-unit.482713/ Click to expand... do you know where the ground is for the amps? I have no power going to the rear amps. Fuses are good
A Alpha New Member Jun 2, 2019 1 0 1 Wisconsin Jun 2, 2019 #5 Jun 2, 2019 #5 Hey Ace305 did you ever figure out the problem with your sound system? I have the same exact problem and I am at a loss. Any feedback would be greatly appreciated. Thanks!
