Whats up guys? Just thinking about setups for my 351 in my 95.
Im pretty sure i will be running some TFS twisted wedge heads on a stock bottom end.
My questions are about the cam, intake, throttle body.
So cam choices i am thinking about are:
TFS stage 1
Lift (intake): .499 in. w/ 1.6 rockers
Lift (exhaust): .510 in. w/ 1.6 rockers
Duration: 221° @ 0.050 intake
Duration: 225° @ 0.050 exhaust
Lobe Separation: 112°
Steeda #19
Lift: .480 w/1.6 Rockers (.516 w/1.7 Rockers)
Duration: 220° @ 0.050 intake
Duration: 226° @ 0.050 exhaust
Lobe Separation: 115°
Recommended RPM Range: 2500 to 6000
Steeda #20 with 1.6rr
Lift: 544 with 1.7 rockers/ .512 with 1.6 rockers
Duration: 224 intake/230 exhaust @ 0.050 lift
Lobe separation: 112 degrees
Custom?
HOW MUCH $$$$$ ???
On trickflows website, the maximum recommended lift is .540". The TFS stage 2 will cause piston to valve clearence with stock pistons which i will have to run for now. I want a good idle with good power. That Steeda #19 has the best LSA of 115 so it should idle like a champ right?
The intake I am pretty set on is the TFS 351 intake. But with the 75mm tb opening (1,500 to 6,500 rpm) or the 90mm tb opening(2,000 to 7,000 rpm)? And so which tb will match those openings well?
Sorry for being so long, any advice, suggestions, tips are greatly appreciated.
TFS stage 1
Steeda #19
Custom?
HOW MUCH $$$$$ ???
