well i made a little progress today. Cleaned the IAC and replaced the ECT. Ran the code 18 troubleshooting checks and everything read as is prescribed. Ran 3 EEC test to check codes.
Test 1 = O 11/15 (battery was unhooked), CM 18, R 12/21/18
Test 2 = O 11, R 21
cleared codes by pulling jumper wire during output
Test 3 = O 11/18, R 11/18 (car at operating temp)
During test 2 it stayed running long enough to do a cylinder balance test and it flashed a 7 three times. Idle was a little better but still erratic. Checked the TPS and reading were .98 with a smooth rise with a push of the throttle. So basically my problem is code 18 with an erratic idle. Sounds like its not timed. Also rechecked timing. Without the spout in timimng is solid at 10 degrees BTC. Spout in and that mark is jumping all over the place. Like 30 BTC to 0 to I can't see it anymore. I have looked through all your checklist and am prepared to clear my mind and start fresh. Which checklist would you recommend?
Test 2 = O 11, R 21
