Ok, I am getting tired of arguing this, but I want to know why the adapter plate method is better than RTV and the PI gasket method.
RTV has been around for a long ****ing time and the big 3 US automakers at one in the past, RTV was how they made gaskets. I know of some RTV gasket made cars running 200,000 kms and counting with no issue of leaks what so ever.
Using the PI gasket, you have to use a small dab of RTV on 2 of the coolant ports, that is it. I posted pictures once where the RTV goes, but I am not looking for them now. It won't fail under boost because boost does not affect coolant flow. It will last because RTV is designed to seal against water and coolant.
What the adapter plates do is lift the intake manifold. Lifting the intake manifold, lifts the fuel injectors which affects the spray pattern. Using adapter plates requires you to use both the NPI and PI gasket, you also have to take that into consideration. You will require a tune using adapter plates to correct the A/F ratio.
The adapter plates have shown no better results( HP/TQ ) than those who just used the gasket and RTV method.
The best method, would be to have the heads port matched to the PI intake gasket with some aluminum welded into the coolant port. I would only consider this, if I was using ported NPI heads.
IMO, the next best method is the PI gasket and RTV method. The adapter plates IMO are a huge waste of money and would be the last method, I would use.
