- Mar 30, 2005
- 37
- 0
- 0
I just finished my PI swap a couple days ago and my AC hasn't worked since. I did some wire chasing under the hood. I chased the compressor wires to the engine harness disconnect. So after that I figured that it was low on coolant after being moved around a bunch (not disconnected). So I went to walmart and picked up some freon and shorted the low pressure cut off sensor. But when I start the car with the AC on the pump only turns on for about a second and a half. So I hooked up the Freon anyway and started and turned off my engine about 20 times with no good results.
Whats the problem?
Whats the problem?
