Im about to get an alarm system for the Mach,but I need some advise/opinions here since its been a few years since I have bought one.Im looking at 2 diff ones but not sure which one I would want or need.What ones would any of you get and why?Just trying to deciede here.Also on my 01 GT it had a DEI alarm but the factory key pads were used with it,does anyone know if that could be done with either one of these,I like to have it that way for backups or if I have to leave the car with a shop or anything.
Here are the two:
Viper 350HV,I can get this for $80 NIB
Viper - Security - Viper 350HV
Code Alarm CA-671,I can get this $130 NIB.
CODE ALARM - CA671
This also comes with a Viper 632T Mercury hood/trunk tilt sensor,this is not wherer I would be getting it from,just put up the link for the specs.I dont really care for remote start and I know it cant be used with a manual.
Well here are more detailed specs for the code alarm:
System features
* Starter disable with selectable active or passive arming
* Super Bright Blue LED status indicator lamp
* 1400' of Maximum transmitter range operating at 433Mhz
* 2 Transmitters in kit
1 Five-button LCD two way with clock/timer lock/unlock and status display
1 Six button transmitter with LED flashlight
* Transmitters feature labeled buttons and use CodeShift Anti-Grab TX technology
* Remote Car Find with flashing parking lights and a progressively louder audible alert
* 5, 10, 15, 20 minute selectable remote start run time
* Diesel Engine compatible with wait to start
* External start trigger
* Crank averaging with voltage sense
* Shock sensor with infrared technology
Features 64 step remote adjustment
2 Zones: Full trigger/Lite touch
* Alarm/Panic features horn honk with Real Panic Sound, flashes parking lights and sounds 127 Db weatherproof siren
* 30 Second alarm duration with 5 trip NYC Approved Noise Pollution Cycle
* 5 Zone input: Door, Trunk, Hood, Shock, Ext sensor
* Coded and Standard Button Selectable Override
* Selectable Arm/Disarm Horn/Siren output
* Dedicated remote panic button
* Programmable dome light entry and exit illumination delay control
* 2-Way communication from the alarm to the LCD keyfob transmitter:
System Status
Alarm Trip notification
Remote start confirmation notification
Countdown remote start timer display
* 5 Auxiliary outputs for headlights, windows up, windows down, door poppers, etc...
* 24 Hour time start mode
* Cold temperature self-start mode
* Selectable turbo timer operation
* Telematics input for remote operation from an 800 number/ or www
* Songbird siren output option
* Plus of course the free Viper OEM merc switch which will save you huge time under the hood.
Instead of using the spring loaded pin switch that every alarm manufacturer sticks us with, just like I do at retail, the hood protection is upgraded
to a tilt sensor impervious to the elements and free from the failure prone springs and pins.
Here are the two:
CODE ALARM - CA671
System features
System Status
