On the fox I've run the 15* you mentioned (on 87 octane). If it gets real hot outside, you might need to back it down.
Now if you have a 94-95 processor, you'll be lucky to run over 10* base. Those processors are hugely load-based (they can have over 40* advance beyond the SPOUT out setting). Yes, that means they can see over 50* total timing.
For a safe advance point, 12* is pretty safe for a fox on low octane. But no motor is the same so just keep an ear out for pinging.
Good luck.
