im building a 11.2:1 compression 306. wiseco flat top pistons with two valve reliefs eagle sir I beam rods eagle crank. 58cc heads springs good to 550 lift.1.94 intake valve 1.54 exhaust.1.6 roller rockers .050 compressed thickness head gaskets. its going to be a daily driver motor on 93 pump gas. my goal is to hit 310-320 at the wheels through the aod. I don't want a cam that is overly aggressive but I want the lope noticeable and want a cam that wont be to much lift that I have to worry about ptv clearance or having to put a converter on it to have it work properly since the aod will be swapped for a tko down the road
