firewall....today i jacked it up again and made sure all the flywheel bolts were in at least,couldnt get in there to torque them unfortunately,but i disconnected the cable pushed the arm by hand and the second the throw out bearing touches the flex plate it vibrated,makes me think the flex plate maybe?,"seemed" like the fingers may be not have been perfectly flush.I forgot to ask ...do you have a firewall adjuster/cable kit or just an adjustable clutch cable?
but what i did do was check out my buddies car with the oem self adjustable clutch,he has a centerforce dual friction,it had zero free play,and it grabbed high also,so i basically set it exactly the same,stiff and grabs higher than i like, but its way better,but if i try to adjust it to grab a little lower it gets worse...
