Looks like the EEC cannot increase the fuel trim without the "aid" of some fuel through a vacuum line. Now the issue is to ID why. Did the engine show the signs of a too rich A/F during the KOER under those conditions? (black smoke, rough idle, etc)
Things to recheck:
Exhaust leaks at the headers?
it's fine
Fuel pressure over 38-45 psi with vacuum line connected?
FP is at 33 at idle with line connected
Vacuum leaks? vacuum lines, intake gaskets, no open breathers present, PCV valve operational and sealing, canister purge line connected solenoid/CANP or plugged.
they all check out fine except a little problem with the pcv valve grommet
HEGO ground wire attached to rear of intake manifold stud or cylinder head bolt? (orange wire)
i took it from the firewall back to the intake bolt a couple days ago
Correct 19# injectors installed (orange color)?
yes they are orange stock ones
If all the above is OK, leave FP gauge connected, search for a flexible section of the fuel return line, pinch the line with a set of locking pliers, and confirm pressure increases to +45 PSI engine idling. If it does, run the KOER again with the fuel pressure at the new higher pressure setting and LUK what codes show up.
