The OEM Ford MAFs are not calibrated to injector size. The injector sizing is done in the computer’s internal programming. Aftermarket MAF’s “lie” to the computer in an attempt to fool the computer into changing the injector pulse on timing to match the increased airflow.
The A9L computer was standard equipment on 89-92 5.0 Mustangs with a 5 speed transmission. The only practical way to change the tune was to add a piggy back chip carrier that plugged into the circuit board using an externally mounted adapter. It is very obvious, since it sticks out of the computer housing on the end of the computer opposite the computer main wiring harness connector.
The odd duck is the 93 Cobra computer, labeled X3Z which is internally calibrated for 24 lb injectors. Use the MAF & MAF sensor from the X3Z computer to avoid problems with the X3Z computer's internal calibration.
