- Oct 8, 2007
- 98
- 1
- 0
so after many hours of searching and talking with an engine builder ive decided to do the swap. im planning on running either 393 or 408 stroker i havent decided yet. anyways this is what ive got so far
-351w roller block
-blower cam - ??
-lower intake mani - trick flow "r" for 351 or gt-40 351 if it can be found
-oil pan - 160
-distributor - 260
-stroker kit with 9.0 compression - around 1700
-drop mounts ???
-swap headers - 300
-pro m 90 mm maf for 42 pound injectors - 700
-fuel rail rails - 250
-comp pro magnum rockers - 300
i plan on using as much of my stock cobra things as possable i want to make sure i havent missed anything, also i am not sure of a few things such as what cam to run for a blower application, and what size roller rockers 1.6?? 1.7?? the other things ive had a problem finding was the drop mounts.
if anyone can offer any advice for parts and such let me know, the end goal is over 600 rwhp and keeping it under the stock hood
however the current goal is just getting it running and doing whatever i need to while the engine is out to avoid redundancy
-351w roller block
-blower cam - ??
-oil pan - 160
-distributor - 260
-drop mounts ???
-swap headers - 300
