I finally broke down and pulled the codes off my stang and got these codes:
158 - MAF is/was high output
172 - System is or was lean - Single, Right or Rear HO2S :damnit:
628 - Excessive converter clutch slippage
I was able to reset/fix the MAF problem by cleaning the MAF with that elec cleaner you can get at AutoZone and the 172 code is probabily the O2 sensor going/went bad, but my question is what is the clutch slippage??
I was reading on another forum that if the output of the engine does not match the TPS input of the engine, it could throw this code. Would that mean the TPS sensor is going or is bad? Anyone have one as a spare I could put in to correct this problem?? :worship: Or am I W A Y off in reading into this?
