I couldn't find this in the FAQ's....What is the correct jacking point on the front of a 5.0? I've been jacking up on the front subframes, but the metal is surprisingly weak and gets dented from my jack. Thanks.
Either under the k member, or under an A arm if you can get by with only jacking up one side. You can also use the sway bar if you're careful. DO NOT use the oil pan (seems like common sense, but you'd be surprised how often it happens).
I wish the previous owner of my fox knew how... you should see my rocker panels. The stock jacking points using the stock jack aren't exactly clear to see.
