FRPP cams and 4.10 gears
faspony
56
Hey,
I have seen and heard so many Youtube videos of Mustangs idling w/ frpp hot rod cams I'm goofy. I'd like to have someone post a video of their Mustang GT on the street or the track and see them in action with these cams. Maybe some facts about how well they perform or not.
Another concern of mine is all this talk about 3.73 gears and 4.10 gears.
I'd like to install a set of gears in my 06 GT but I am not sure just how much I will lose at the top end. How much do these gears effect the RPMs around say 70 MPH? What effect do they have on gas mileage?
I have done a search and found a few good threads but I'm still not convinced which gears work the best.
What say you, ya'll
  • Sponsors(?)
99nightmare
all out performance go with the 4.10's or either 4.33's if you want to just have some fun the 3.73 will give a nice boost. You will lose some mpg but that is a personal decision. But you will have to get a tuner or take it to a shop to have the speedo recalibrated after the swap.
GooTh 08
Only about 1 mpg with the 4.10s. Why are you so concerned about loosing top end? how often do you actually drive over 120mph? as far as rpms go there is only about a 300-400rmp increase at 70mph with 4.10s compared to the stock 3.55s. Your rpms really have nothing to do with mpg it is all about how much you put your foot into it. in that case you will probably see a loss of about 1-4mpg not from the gears but from your foot. 4.10S are the way to go!
ViperNuge
197
Maui
I have a Viper truck that I went from stock 4:11 to 4:88. Truck feels like it is 1000 lbs lighter. One of the best mods I have done. I imagine going from stock 3:37(?) to 4:10 gears would feel about the same on a stang. It will be one of my first mods when I find my stang.:nice:
patrick
cycosarge
50
Fayettenam, NC
I run my car at the Maxton Mile. 4.10's would be too steep as I am trying for over 200 mph. the 3.55's are good if you want that kind of top end, but for a normal car, I don't see why 4.10's wouldn't be the best choice.
walter
1,054
Houston TX
www.facebook.com
While gears are a big issue with top end unfortunately the biggest obstacle to the 2 double 0 mark is the car's lousy aerodynamics. The 05-09 S197's are about as aerodynamic as a brick wall. Drag and stability are insane past 160MPH. That's why as ugly as the 10's can be they managed to drop the cd significantly by tweaking the car's shape.
cycosarge
50
Fayettenam, NC
I wholeheartedly agree with you. The last time I was at the Maxton Mile, I ran 186 mph. So, I upped the boost to 20 pounds, added fuel pressure and tried it again.... 186 mph. Adding 75 HP to the wheels added nothing to my top end. I am now looking at running 25 pounds and a water/meth injection system.
scottfree
23
Little Rock, AR
www.myspace.com
build a nose cap like a 1970 superbird. hehe
Thread starter Similar threads Forum Replies Date
D Frpp Hot Rod Cams Help! 2005 - 2014 S-197 Mustang -General/Talk- 8
jazzystang FRPP or Mutha Thumpr Cams 2005 - 2009 Specific Tech 4
O SOLD Brand New FRPP Hotrod Cams w/ Phase Bolts Engine and Power Adder 5
Edd204 detroit rocker cams or frpp hotrod cams, need help choosing 2005 - 2014 S-197 Mustang -General/Talk- 4
CRoberts91 4.10s and FRPP Hot Rod cams 2005 - 2014 S-197 Mustang -General/Talk- 12
Butterfinger AFR165 with FRPP E cam Fox 5.0 Mustang Tech 20
X Long Tube Headers or FRPP Cams First ? 2005 - 2009 Specific Tech 6
stangraccer Anyone have the FRPP Blue Cam Covers with a Torch Red car?? 2005 - 2014 S-197 Mustang -General/Talk- 0
R frpp hot rod cams 2005 - 2009 Specific Tech 6
ufnavy06 Got the FRPP HR cams in 2005 - 2009 Specific Tech 12
T FRPP cams install 2005 - 2009 Specific Tech 7
Tanus F/S FRPP cams, and aluminum valve covers Engine and Power Adder 7
C COMP CAMS STAGE 2 CAMS or FRPP HOT RODS 2005 - 2014 S-197 Mustang -General/Talk- 2
06Hoss frpp cams 2005 - 2009 Specific Tech 5
F FRPP Hot Rod Cams Question 2005 - 2009 Specific Tech 4
blacksheep06 FRPP Cams, where to order them? 2005 - 2009 Specific Tech 7
mustanglouie Frpp cams installed (video) 2005 - 2009 Specific Tech 4
M FRPP Hot Rod Cams Installed 2005 - 2009 Specific Tech 59
H What 4.6 FRPP PI heads take out cams SN95 4.6L Mustang Tech 1
jtfairlane FRPP E303 Cam Fox 5.0 Mustang Tech 2
mustangman9812 Maybe Changing Mod List - FRPP Blower, PI Cams, Nitrous? SN95 4.6L Mustang Tech 8
A Cam For Frpp Blower SN95 4.6L Mustang Tech 4
D FRPP CAI 2005 - 2014 S-197 Mustang -General/Talk- 0
fredfifty Fox Which Ps Hose After Frpp Ac Delete Kit Install? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
gruvee87vertgt Fox ? Frpp Ac Delete & Power Steering Bracket & Alternator Bracket Compatible ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
a50ina50 SOLD Frpp Gt40x 58cc Heads, Bolts And Gaskets Engine and Power Adder 0
Nutty 5.o Is This What The Frpp Adjustable Cable Is Now? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
MFE92 SOLD Frpp 1998 Cobra Wheels Wheels Tires Brakes 0
MFE92 Expired Frpp 1998 Cobra Wheels Wheels Tires Brakes 0
89gtsleeper Taylor Vs. Frpp: My Wire Resistance Specs Fox 5.0 Mustang Tech 7
95Nelson Expired Frpp - K&n +tuner For '12 Gt Manual Trans Engine and Power Adder 2
TOOLOW91 SOLD Frpp 42lb Injectors 250obo Engine and Power Adder 0
T Expired 4.10 Frpp Gears New Drivetrain Parts 0
timjimmy Fuel Frpp Manifold/tbi Whistle/whoosh 2005 - 2009 Specific Tech 2
T Expired 42# Frpp Injectors Engine and Power Adder Parts 0
Farrell5.0 Expired Brand New Frpp 3.27 Gears Drivetrain Parts 6
Gearbanger 101 Engine Anyone Here Running Frpp "boss" Head Gasket M-6051-cp331 In A Production 5.0l? Fox 5.0 Mustang Tech 16
1 Cel After Frpp Intake Installed 2005 - 2009 Specific Tech 14
K SOLD Frpp 2000 Chrome Cobra R Wheels With Tires Wheels Tires Brakes 0
Modular2v Expired 42# Frpp Injectors And Lightning Maf Engine and Power Adder Parts 1
M SN95 Kyb Gr-2 Shocks/struts With Frpp B Springs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
mikestang63 Frpp M-5500 Rear Upper Control Arms, $200 Bucks? Fox 5.0 Mustang Tech 47
RangerJoe Frpp Lifters 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
timjimmy Engine Frpp Intake Manifold 2005 - 2009 Specific Tech 2
RickieFrat SOLD Roush/svo Frpp Supercharger 2v Engine and Power Adder Parts 5
astronut1885 Expired Ford Racing 1983-2004 Mustang Leather 5-speed Shift Knob Frpp Interior Exterior Parts 0
A Expired Flowmatched Frpp Green Top 42lb Fuel Injectors Engine and Power Adder 0
RangerJoe SOLD Frpp 3.73 Drivetrain Parts 0
Nightfire SOLD FRPP 42lb/hr fuel injectors Engine and Power Adder Parts 2
