I was installing my new clutch and flywheel and i stripped one bolt into the crank.
Well like a idiot wasnt paying attention thought the new bolts they give u with the flywheel where the ones for the crank. Started to tighten one down and it started to strip and once i saw that i pulled it back out and the stock one wont tighten into it now. The stock bolt screwed up when i tryed to put it back in. I got a tap and ran the tap through the crank bolt hole and the tap went in ok and held. It looks like it will be ok. The tap goes in further than the bolt goes. I called summit and got the arp studs for the flywheel i hope those will work. They say there longer. Do you guys think that will solve my problem?
