Idle issues with a foxbody and microsquirt
Nightstang00
133
12
28
35
I am new to tuner studio and microsquirt. I hooked up everything and got the wide band setup. I calibrated the sensors and verified timing. When I start the car up it starts fine but hangs at 2k for a few mins. I blip the gas and it will lower Rpms after the engine warms up. Then it still hunts and or surges. I was playing with a few things but can’t seem to get it right.
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,194
6,099
204
31
Hillsborough county
idle is the most difficult thing to get right for the beginner. the big things to look for are the AFR and timing at idle. if the AFR is swinging the idle will never get steady.
please post a datalog of the car starting and idling along with a copy of your current tune file.
for help beyond just advice check out my services page link in my signature.
Reactions: Nightstang00
Nightstang00
133
12
28
35
start up was after the car was warmed. I am thinking i may have messed up timing
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,194
6,099
204
31
Hillsborough county
ok i setup a tune file that should work much better as a starting point. please tell me how you set the timing on the car, there are only a few correct ways to get it done. I noticed the WB showing some very lean spots during idle, you may want to pull a plug and see if they are fouled out.. a miss will show up as a lean spike.
datalog this tune file for me.
Nightstang00
133
12
28
35
Will do tonight after work. I appreciate your help here.
I used fixed timing and verified 14 at the crank and at the trigger wizard. Then I changed it back to use table. It just seems high to idle at 25-30 advanced isn’t it?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,194
6,099
204
31
Hillsborough county
that is what your timing table was commanding so thats what it was idling at. ignition timing at idle is heavily dependent on the cam used and what condition you are tuning for.. as an example a stock or mild cam on a car using catalytic converters may want retarded timing while warming up to get the cats good and hot.
Some large cams like advanced timing [usually narrow LSA] and others with the same duration but a wider LSA may like lower idle timing.
my hard fast rule is this 'give the car what it wants'
the stock ecu will command around 20* at idle
Nightstang00
133
12
28
35
Got ya. Ok. I have a trick flow stage 1. I’ll load the tune later tonight
Nightstang00
133
12
28
35
Idle still started high, i started playing around with the fuel table to lean it out in idle range and it started to lower. I then looked into afterstart/warmup enrichment adjusted that due to it being so rich . I had it idling at 11/12 and like 980-1000 rps but still dropping to 8 at times and then i hit the gas a few times and it went all over the place. then my laptop died so it stopped.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,194
6,099
204
31
Hillsborough county
You should not have touched the after start ase or wue, they get tuned last after the ve table is tuned. You cant tune the ve table until the car is up to full temp... everything has an order that must be followed or you will run in circles.
Nightstang00
133
12
28
35
I take it you did not load the tune file and then cycle the power?
Ok I’m sorry , I didn’t know that.
I loaded the tune then turner studio asked me if I wanted the setting from tuner studio or the computer I guess. I clicked tuner studio since I loaded the tune in.
Nightstang00
133
12
28
35
Ok i can reload it and power cycle it tomorrow morning. I’ll make sure I just log it and I’ll send it over.
Again , appreciate the help!
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,194
6,099
204
31
Hillsborough county
nope load it in and datalog for me please... if it idles steady with a reasonable AFR [13-14.8] then back the idle screw out 2 full turns. or until the car idles steady at 700-750 rpm.
Thread starter Similar threads Forum Replies Date
C Engine Gray smoke from exhaust. Smells like gas. Fox 5.0 Mustang Tech 15
J Idle Adjustment Issues 2.3 Turbo fuel injectedto 2.3L (N/A & Turbo) Tech 1
0 4.6 2v SOHC 2k rpm Idle, help reading engine data SN95 4.6L Mustang Tech 0
R Engine Remove the Idiot from the equation. Idle/hesitation issue. Fox 5.0 Mustang Tech 3
C 2014 Mustang Gt/Cs Idle and dying issue 2010 - 2014 Specific Tech 2
J Idle issue still!! Replaced several parts.. looking for more ideas!! Fox 5.0 Mustang Tech 12
S Another Idle surge post with microsquirt Digital Self-tuning Forum 5
A New fox owner, idle issues need some advice Fox 5.0 Mustang Tech 20
J 2000 GT Idle/Running Issues SN95 4.6L Mustang Tech 6
B Slight surging idle issues Digital Self-tuning Forum 14
S Megasquirt PNP2 460SBF startup/idle issues Digital Self-tuning Forum 9
F Idle Fluctuation Issue 98 GT SN95 4.6L Mustang Tech 0
D Engine Idle issues Fox 5.0 Mustang Tech 23
T 91 mustang idle surging Fox 5.0 Mustang Tech 5
Xenogenesis Timing issue at idle SN95 V6 Mustang Tech 1
justinmurray2001 idling issues SN95 4.6L Mustang Tech 6
F Water pump issue at idle Fox 5.0 Mustang Tech 17
S Megasquirt pnp idle issues Digital Self-tuning Forum 19
L At my wits end...96 Cobra idle and other issues... 1996 - 2004 SN95 Mustang -General/Talk- 3
S Idle issues, missfire, backfire, stalling 1994 - 1995 Specific Tech 29
9 MS2 Cold Start Issues Digital Self-tuning Forum 6
V Exhaust AEM AFR no reading at idle Placement issue ? Fox 5.0 Mustang Tech 4
Joe Medeiros Idling issues 1965 - 1973 Classic Mustangs -General/Talk- 2
O Engine Code 12, 92; Code 12 will not go away! Fox 5.0 Mustang Tech 25
Onesick99GT Low rpm stalling fix 1996 - 2004 SN95 Mustang -General/Talk- 0
Onesick99GT Speedometer Not Working Fix SN95 4.6L Mustang Tech 0
S Idle problem 1990 with gt40 crate engine 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
C Idle Hanging (Solved) and stupidly simple. 1996 - 2004 SN95 Mustang -General/Talk- 2
M Weird Idle/Power Issue SN95 V6 Mustang Tech 1
Dustin2v Engine Please help! Issues starting, running, idling SN95 4.6L Mustang Tech 4
M 1994 Ford Mustang GT 5.0 idle issues Fox 5.0 Mustang Tech 1
L Engine Rough Idle at Start, Possible CMCV Vacuum Leak 2015+ Specific Tech 0
C Stalling and idle issues 2005 - 2014 S-197 Mustang -General/Talk- 3
S 08 GT idle/emission issue 2005 - 2014 S-197 Mustang -General/Talk- 1
S Engine 2000 Mustang Idle issue SN95 V6 Mustang Tech 1
Cnorth94 BBK throttlebody/plenum combo idle issues 1996 - 2004 SN95 Mustang -General/Talk- 0
N Engine 1987 LX 5.0 5 Speed - idle and . . . Fox 5.0 Mustang Tech 4
Onesick99GT 99 Mustang GT High Rev On Cold Start SN95 4.6L Mustang Tech 25
N 95 convertible idle issues stange power surges 1994 - 1995 Specific Tech 6
N 98 Mustang GT will not idle 1996 - 2004 SN95 Mustang -General/Talk- 7
N Car doesn’t want to idle anymore after supercharger install 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
C Engine 1988 gt high idle and throttle issue. Fox 5.0 Mustang Tech 3
B Engine 1998 GT - Weird idle and misfire issues SN95 4.6L Mustang Tech 6
M 1994 Mustang GT 5.0HO - Idle issue - Seeking advice Fox 5.0 Mustang Tech 6
H 03 4.6 SN95 Idle issues 1996 - 2004 SN95 Mustang -General/Talk- 2
B 2002 GT bad TPS values and idle issues 1996 - 2004 SN95 Mustang -General/Talk- 4
A Engine 94 gt 5.0 sporadic idle issues 1994 - 1995 Specific Tech 4
M High idle, big mystery 1996 - 2004 SN95 Mustang -General/Talk- 3
K Fuel 1993 LX 5.0 5-speed - Starting/Idle issues Fox 5.0 Mustang Tech 8
C Engine 1999 Mustang V6 / Engine is Tapping but Not Knocking goes away after 1 - 5 mins idling / Possible Oil Pump? SN95 V6 Mustang Tech 2
