Idle Surge. Where Should I Go First?
Brian Wilson
Hey guys. I'm new to this forum. My name is Brian. I have an 88 GT with heads, cam, injectors, etc. I am getting an idle surge and sometimes falls flat on its face when i come to a stop. I was thinking tps but though I would put it out there for you guys. All info is appreciated. Thanks.
Have you run the engine codes?
More details on the actual mods themselves? What cam? What heads? What injectors? Is the MAF calibrated for the injectors? Is the car even mass air swapped?
Reactions: 1 user
After you figure out what you actually have in terms of engine and modifications, then proceed to the advice below...
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 200,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
Thanks for the info. I'm sure it will help.
