Is it worth it
BeastyVas
Las vegas
Hey folks , so from my understanding the only difference between the 99-04 Pi motor and my 98motor is the heads and cams. if i’m wrong please correct me. but as i’m looking into the trickflow top end kit , do i have to buy a 99-04 motor to get it to work ? or will it just bolt and work right into my 1998? thanks again.
-Nick
wmburns
SN Certified Technician
Aug 14, 2009
5,209
397
164
Houston Texas
The pistons are different. Which is one of the reasons why if you put PI heads on a non-PI bottom end the resulting combination has a higher CR.
Knowing what I know now I personally would not replace heads while the motor is still in the car. The whole Mustang motor is not all that hard to remove and the access is so much better on an engine stand.
I personally think the lower cost option is to use a whole salvage yard PI motor from a Ford PI Romeo from a 2001+ Panther (Crown Vic, Grand Marquis, Town Car). Try car-part.com for some sample prices in your area.
Dark04GT
664
40
49
NC
Non-PI (NPI) SOHC engines have an 11-cc dish along with a 51-cc combustion chamber. The PI head has a smaller 42-cc chamber and a deeper 18-cc dish. Matching a set of PI heads with NPI pistons is a recipe for a much higher compression ratio.
This is why the trickflow heads come in two sizes - even with the bigger chamber size trickflow top end kit you’ll still increase your compression ratio. Added compression ratio pros and cons should be considered when planning out your future mods for what you want from your car.
