i have a 98 Gt 5 speed and i am routing a wire from the engine bay to the cockpit is there a hole in the fire wall to put it through if not how would you get the wire from the engine bay into the cockpit
There is a hole, look harder, look from the engine bay side, near where the steering wheel is, then get down on the driver side floor with a flashlight.
another way to do this would be to go thru the fender into the door there is a rubber vent duct in there that you can run the wire thru then under the carpet and back (people may tell you going thru here will make it rub when u open the door causing a short) but it doesn't.....the wire is in there loosly and touches nothing.
I went through the firewall on my 03. What a PITA! I had to use a combination of needlenose pliers and a center punch to get through that rubber piece. I wanted it to go trough it and not simply around it so that it wouldn't be touching the bare metal and possibly rub.
