Light Bar Question
koala33
181
Fort Belvoir, VA
My car has a light bar. When I hit the brakes, I get nothing. I have no idea if this was ever hooked up properly, and I would hate to take apart the backseat.. But I am wondering if the LED is even replaceable in these (assume maybe the LED is burned out)? I am assuming it is a classic design concept light bar. I think I should take the whole thing apart and re-paint..
The wires run down one side of the light bar and then are wired into the rear brake light harness. Start in the trunk- look forthe wires to see if they are there, check the connectivity, and work your way back to the light bar. Removing the rear lower seat is 30 seconds- push in the bottom center and lift up.
Outstanding, I will check it out. Do you know if the LED itself is replaceable if burnt out?
--Shawn
