Hi guys,
I am new here and hope someone can help me out with my problem I am having with my 1995 Mustang V6.
Her is what happend, I purchased the mustang with a overheating problem.
The problem was in a blown head gasket. Replaced all upper engine gaskets and flattened the cylinder heads.
Just to be sure I also changed the water pump.
Behind the water pump is the timing cover. That was leak water trough it's gasket so I had to pull it of the engine to replace the gasket. While everything was of the car, I also put on a new timing chain, sprockets and tensioner.
After all the parts being replaced and put back on the car (also did a tune up on spark plugs, wires, olie and air filter, belt tensioner and belt.
Then I started her back up. It ran very rough and was rocking all over. After a vacuum problem solved it ran a bit better, but still not good. Also it died a couple of times.
The code a got was a random misfire code. I changed back the new (Motorcraft) plugs for the old ones.
Now I am only having a misfire code of cylinder #5. But can not get it running smooth again.
Before I got working on the car it ran very good and smooth it only had the over heating problem.
Hope someone can help me out! Much thanks in advance.
