I have a crane cam and I need to know which timing chain is the correct one? I bought the Cloyes 9145 and that did not fit, the teeth pitch is 1/4 and not 3/8. So I bought the Cloyes C163 and the chain fits the sprockets. I tried installing the chain together with the cam and crank sprocket and cam pin is in the hole of the sprocket and I can't get the cam gear to fit flush so I can put the bolt in. I don't know why it won't fit? I don't want to force it on and should it fit like a glove? I compared the chain to one that came off the car and it looks the same. Why won't this timing chain fit? Do I have the correct timing chain? On Rock Auto here are all the chains that are available and there is also a Cloyes C370 chain but I don't know the difference between the other ones. Which chain will fit?
CLOYES Part # C163 High Performance
View attachment 128765 View attachment 128766 Links: 58; Pitch: 3/8 in.; Rollers: Double; Double Roller; For Non-Factory Roller Cam; Heavy Duty Timing Chain; SVT Cobra; GT Model View attachment 128767 $10.59
CLOYES Part # 9145 High Performance View attachment 128768
View attachment 128769 View attachment 128770 Links: 58; Pitch: 1/4 in.; Rollers: Double; Double Roller; Street True Roller Timing Chain; SVT Cobra; GT Model (Only 3 Remaining) View attachment 128771 $14.41
CLOYES Part # C356
View attachment 128772 View attachment 128773 Links: 58; Pitch: 3/8 in.; Plates: 9; Silent Type Chain; GT Model View attachment 128774 $15.19
SEALED POWER Part # 222163
View attachment 128775 View attachment 128776 Double rlr.; 58 Links $17.19
CLEVITE / PERFECT CIRCLE Part # 9370
View attachment 128777 View attachment 128778 From 7/26/94;Silent Type
$23.79
SEALED POWER Part # 222370 View attachment 128780
View attachment 128781 View attachment 128782 Silent type; 58 Links $23.79
CLOYES Part # 9130 High Performance
View attachment 128783 View attachment 128784 Links: 58; Pitch: 3/8 in.; Rollers: Double; Double Roller; For Non-Factory Roller Cam; Hex-A-Just/original True Roller Timing Chain; SVT Cobra; GT Model
CLOYES Part # C356
