- Jul 5, 2011
- 4
- 0
- 0
Hey guys,just joined mainly to see if anyone has had the same problems I have and if there are any simple solutions.I just finished over the holiday weekend putting a set of ported and polished P.I. heads and a ported and polished Eldebrock Torker II intake with the 1406 Eldebrock Performer carb on the 98 Mustang I inherated from my daughter.I have the MSD Mod6 ignition module to fire things off.A set of Trick Flo valve covers looks good also.Also put a 3 row Aluminum radiator in it for good measure with a 170 degree thermostat,also a set of BBK shorty headers and 2 1/2 inch exhaust into 40 Flowmasters with a X pipe in between.I had to step down fuel pressure into the carb so I went with a Summit fuel regulator with a return to get the job done.Also added a 40 amp relay to turn on pump anytime ignition is on.Sounds great ,runs like a scalded dog,but and here it is,the question. Nothing from the computer will work, I get no fuel pump signal(dont need it ,but I checked) the AC wont come on ,the electric fan on radiator wont come on.So what tells the computer the engine is running? there must be an input to the brain that tells it its running.Anyone got any ideas?I could power all of that externally with relays,and if I have to, I will but anyone done this before and figured it out?Thanks in advance.
Tom
sorry so long winded.
Tom
