Hello all, I'm new to this forum and did search the posts but couldn't find an exact solution. I have a 1968 Fastback with 17x8 Rims. The following components have been replaced/added. Front/Rear 1 inch Sway Bars, New Shocks/Springs. I just replaced the upper/lower Control Arms and Inner/Outer tie rod ends. It was aligned by a professional shop. Power steering, front disc brakes.
- During the tie rod replacement, I tried to put TCPs Bump Steer Outer tie rod ends on, but they didn't fit (maybe I have Granada discs) however the Mustang Outer Tie Rod ends bolted right in.
- The car still feels wobbly on the road and the steering does not return to center in a turn? The steering is tight. What should I be looking at? IF it is Granada spindles, do they need to do a Granada alignment? Thanks.
