so the plan for this holiday weekend was to at least finish up the motor enough to measure up pushrod length and get it sealed up. well, long story short, that ain't going to happen until after the new year now
now, long story long, with pics!
i had woody paint the block black when he built this thing, and the more and more i looked at it, the less and less i liked that decision, so i decided to change it.
of course, that was AFTER changing the oil pan and timing cover gaskets that were siliconed in
and here's where things just got wacky
earlier in the thread, you'll see that i originally had bought arp BOLTS for these heads, and found out the hard way that the bolt heads wouldn't fit past the valve springs. so i ordered studs, and of course since im tooled for hex and despise 12-point fasteners, can you guess what which set i ordered? yup, the hex set that, while the nuts will go on the studs, also means that the needed 3/4" socket wont fit around the spring either
so i got to
about it, and remembered i had some cheap chinese sockets just laying around and decided to see if i could ghetto rig a (short term) solution. heres what i came up with.
yup, thats a corded drill in a bench vise and an angle grinder. you can see where this is going right?
got the corners down to around .020-.030" thick. ended up working fine at 25 and 50 ft-lb, but first fastener at 75.....
so ill have to rig up another once i get some 12-pt nuts ordered
so after that fiasco, i thought to myself," well the head is at leas attached now, so i guess ill check pushrod length and try to order everything at once. what could go wrong?" shouldn't have asked that.
yup, my old tfs mock-up tool is waaaaay to short
so now i get to either find some all-thread the right size tuesday, or order a new tool.
so anyway, heres how it sits now, just to show it off some since that apparently is all i can do right now
