***So as the title states, I am thinking about building an N/A engine for my stang. I know FI makes more power, and have considered it quite a bit. However, I am not after monster power, just want a strong running reliable engine that meets my requirements. I know this is the more expensive route but I also want something different. Below is my build sheet, please let me know what you think, I have done quite a bit of research and could use some more good links/threads/builds.
Thanks!!
Block
5.0 Iron Big Bore
Heads
Either Foxlake/Livernois or Patriot Per Stage 3
Internals
Cobra Crank, Forged H Rods and Pistons to give me just under 10:1 CR
Cams
I am still researching, but prob stock cams, degreed or something similar to stock. I do not want any idle chop, they will not pass here if they have chop
Intake
Either Stock PI or HPS, I haven't decided yet
Exhaust
JBA shorty Ceramic headers, I know they do not provide much of a gain, but they are better then stock (proven, although small gain) plus they look better too. Long tubes repeat longtubes are not SMOG LEGAL so please don't suggest them.
Misc
70mm TB
C&L Plenum
Windage Tray
High Volume Oil Pump
24# injectors
Maganaflow X with Cali Cats
Goal
I want a solid engine that is DD capable and my goal is 325wrhp, anything more is just
Thanks for looking or helping me out. I plan to do some suspension work too and will due a full build thread if I go with this build.
Thanks!!
Block
5.0 Iron Big Bore
Heads
Internals
Cams
Intake
Exhaust
Misc
70mm TB
C&L Plenum
Windage Tray
24# injectors
Goal
