i installed cam and crank assembly, went smooth no problems. i installed new cam thrust plate and timing set and torqued cam gear bolt to spec(40-45ftlb) now the crank and timing set wont turn. looks like the bolts heads from the thrust plate are hitting back side of cam gear. its binding up somehow... what stupid thing am i missing? i know its something simple. (there is no eccentric) and i never removed any type of spacer. help?
