I bought some good welding cable from a local place here to run from my hatch mounted battery. I need to run it from the battery, to the disconnect switch, then to the solenoid.
I bought some cable ends that look like this View attachment 382490
And im wondering what the best way to attach these things to the end of the battery cable is.
I have tried one method where you put the terminal in a vice, take a propane torch and start dripping solder into the terminal, then when its almost halfway full of solder, you shove the battery cable end into the terminal, and hold it until it dries. Is this the best method? Or is there another method that works better?
