Some of you may have seen my thread about replacing my front suspension, and I've pretty much decided on what Im going with there. The question now is when should I do it? Money is going to be a little tight again this year, so it looks like Im only gonna be able to do one major project this winter. Hopefully I'll have the cash to finish both projects by early summer(May/June). Here's my choices,
A, Replace entire front suspension and continue to use the stock T-5 until I can afford a TKO.
B, Replace just the k-member and install a TKO setup.
C, Same as B, but swap out my sportlines for my stock springs...
My reasoning for each choice is A, I'm sick of the harsh ride with my sportlines. Im also 100% definitely changing the k-member this winter, and I would like to change everything in one shot. My T-5 is holding up just fine so far, and replacing the suspension will hopefully make the car enjoyable to drive all the time again, even if I have to go easy on it.
B, The transmission is definitely a higher priority than the suspension, as far as potentially broken parts goes. I allready broke one T-5, and I would hate to put a bunch of money into the suspension then break the transmission shortly after that.
C, Im tired of the harsh ride, and this seems like the easiest, cheapest fix.
My oil pan gasket is leaking bad, and Im definitely changine the k-member this year since I couldn't afford it last year. This is something I want done before I drive the car too much more, I really don't like driving it with oil leaking right onto the headers...Anyways, I have to disassemble the front suspension to change the k-member, and I would really like to only have to do that once.
