HISSIN50 said:I wouldnt use motor oil or anything else when there are quality synthetic ATF's out there.
+1, the WC T-5 cannot run motor oil or gear oil. It's just too thick. It needs the thinner ATF to lubricate the inner bearings. The trans may shift fine, but you are hurting the bearings on the mainshaft (which is expensive)
Early non-WC t-5's could run the thicker gear or motor oil...82-mid 84
