So, make friends with the service department. Tell the service manager he lost weight. Bring in donuts for all the guys. Stuff like that there.
Dotanukie said:Where would they draw the line at voiding your warranty?
Kravin said:... but tints and rims and stuff like that wouldnt void the waranty would it ??
fordman05 said:You are all wrong, I am a senior master ford tech. this is how it works. The service writter generates a RO (repair oder) It is dispatched to the technician or dispatcher. The technician has the call to say a repair is not warrantable. then the service manager and or ford would get involved if they thought it was not warrantable. get to know a ford tech......The only claims I would turn down is if they were very obvious that someone or some aftermarket component caused a failure.. Most techs I know do the same, just talk with your ford tech if you have questions. Nicks post is also one to listen too.[/QUOTE
The law requires the dealer to fix the items that are covered so don't believe you make the call on what's covered or not. sure you could write something up as if a failure was not caused by modification and get it covered but if no mods were made and the part fails you have to fix it under the warranty period & terms. most dealers I know like the work.
stkdidy said:federal law states that it is a CRIME to void a customer's warrenty unless a modification can be proven the direct cause of part failure, in which case only the part or parts in question have their coverage voided.
most obvious void is a supercharger of course, which can be proven the reason the engine, tranny, drivetrain, rear end, etc might break. in this case, only the warrenty on the parts in question is voided. if ur airbags have a malfunction and go off randomly a wk after the SC install, they are still covered unless the blower directly caused it.
funny, the dealer that we worked with excitedly questioned me on all the mods i planned and wanted for the stang as soon as i bought it, same with the head mechanic there
