After replacing the factory k member with a UPR one, how do I jack the fron of the car up. I used to use the kmember in front. how are the rest of you's doing it?
When I had the tubular K-Member on mine, I drove the car up on plastic ramps. If I needed to get the tires off I jacked the car from behind the front tires on the subframe, put jackstands behind both front wheels on the subframe, then pulled out the ramps.
