Yes, I know. The only reason its out there is because the driver side had to be out that far to get tight. I wanted them to match, so I put them both out that far. On the driver's side, either the tailpipe is too small, or the tip is too big. I tighten the tip all the way down, and its still loose. For some reason, if I pulled them out that far, they got tight. So I drove around a while with the driver's side tip a little loose. Well, I was doing donuts in an empty parking lot, and I guess the G forces were enough to make it fly right off, lol. I lost the little rod that hangs the tip, so right now, I don't have a tip on the driver's side tailpipe. (Hence I didn't post any pictures that show the rear left)
Magnaflow is sending me a new one in the mail, so hopefully by this weekend, both will be tight, and in the correct place. Man, you guys notice everything!
