right side in the middle of the cam cover, hope you bought an OEM Ford one
right side valve cover???? driver or pas side???? whats connected to it?
i need details..im kinda retarted. o and yea I got the ford one Part# D9ZZ-6a666-a
well, you got the wrong one as the D9ZZ-6A666-A fits 2001 back.
2002 up Mustangs use a 1/4 turn/twist-in one and the part # for the "pre-heated" PCV valve is 2C5Z-6A666-AA or for a Non-heated one its 2X4Z-6A666-AA
oh and the rightside is the passenger side of the car
ok thanks!
you would think that if one went to a ford dealers parts counter and asked for a PCV valve for a mustang GT..they would give you the right part... Apparently ford dont know there cars parts. Randy? can u get me one?
i know you from Mustangboards.com
well I can't speak for my "counter-parts" in this business but Im starting to hear this alot more
we sure can order one if you like do you want the $30.00 pre-heated one or the $10.00 non heated one? and I'll have to order it, about 1 day toget
I would like the NON heated one. let me know if your need anymore info.
nah, Im good. I'll try and have one here tomorrow. will keep you posted
Not to hijack, but whats wrong with a non Motorcraft one? I bought a Purolator to replace mine.
I have to ask, whats the difference between heated and non-heated?
aftermarket ones are not made to Ford spec's and can have a larger orifice which draws more vapor's and clogges-up the IAC and fills the lower intake wth a oily mess
p.s. ST your PCV valve is here, give me a call when you can
well, heat
somewhere along the lines the Wiz Kids in Dearborn had a problem wth PCV valves frezzing-up in cold climates and thought the whole counrty needed to have pre-heated PCV valves, total BS if you ask me
well, heat
A call? ok whats the #???
is it okay to replace a heated one (Im assuming 04s have heated) with a non heated? as you can see from my local, i have plenty of it .
