Tech Discussion
final5-0
Mustang Master
Apr 6, 2003
6,817
DFW Texas
If we were to have a detailed discussion on a subject :shrug:
Is there any technical topic that relates to our 94-95 Stangs
that you feel we have not dealt with or you would like to
discuss more at length :shrug:
Feel free to throw out two or three topics or whatever :shrug:
Grady
And, to a lesser degree, the tendency for the driver-side rear tire to stick out further than the passenger.
I guess I just haven't gotten a satisfactory answer. Some say worn out bushings are to blame, others, claim they came from the factory like that (low tolerance production by ford?)
I have the same problem.
Only on the front AND the back though. :/
On a more serious note I would like more Tranny and Rear end info. Everyone says the Astro T5's/G Force are the easiest swap (direct fit) but are they holding up? I have yet to see a 94/95 Astro T5 or G Force talked about in depth. I know Nobody has one and from what he told me he loves it. Even gave me a vid of a pull he did, but so far he's the only one I know of. Can't think of anything else as this time.
I would like a really good writeup of a convertible top install (not the PDF thing that goes around)...
Other items:
Get back to the basics, what cah be taken off the car to save weight, what it weighs, stuff like that.
Maybe a what works and what doesn't. What part has been the best quality , instructions, whatever, what has been the worst.
oh and of course, which gears should I get... :)
More agressive timing, the 88 93 mass air cars had a little easier time with bumping timing. The timing tables are slightly higher on the fox cars at the time.
For me, I really like all the suspension discussions, i'm a big fan of corner carving, and one of these days i'm going to actually install the watts link I bought wayyyy back when. Just havent taken the time to clearance the trunk space and reroute my Exhaust pipes. I believe you can get it to work with the rear exit pipes, it'll just be very tight.
Ohh and we need a good write up on old school methods and new school methods for fixing/testing parts.
what would cause the 93 and older cars to dyno more power than the 94/95 with the same h/c/i kits
ehh the cure for dead spot is simple, replace front bushings / steering rack/ steering shaft...
expensive yes, but that solved my dead spot problem..
I think if you willing to search and combine stangnet with that *other* site and the maximum motorsports site, theres not much that has not been covered..
I think we need stickies of the basics what tire size goes with what rims, gearing, transmission specs, block strength,things likethat :)
Difference between 302 and 305 (chevy)
Easy. The Chevy is more or less a boat anchor. The 302......well it's just damn good. :rlaugh:
No seriously though, Engel saying we just need stickies of all this info makes me want to compile all this information. I mean we all have endless amounts of info at our fingertips through the internet, but it's the finding it that can be the real hang up sometimes. I think it would help everyone out and help clean up the forums cause there'd be less, "What size tires do I need?" or "What size MAF do 94-95 Cobra's come with?" and similar threads.
