5spd GT- I knew you'd like the results as soon as I posted them.I hope to swap the TB to a 75mm or larger one and see what happens. I can't help but to think that it'll pick up a decent amount. My vacuum at WOT goes from -0.08psi at 2000rpms to over -1.1psi at 6000rpms, and I'm measuring this vacuum directly behind the TB. I saw in the corral thread I linked to above that a guy picked up nearly 12rwhp switching from a 70mm to a 75mm TB on his 347 stroker. As for tricks, none were done that I am aware of other than internally balancing the rotating assembly. It took nearly two slugs of mallory to do it, but I think when building an engine of this type it needs to be done. I also upgraded the rod bolts to ARP2000 units. I'm wondering if my oil pump is actually costing me any power as I see over 50psi at idle and nearly 75lbs in the upper RPM's! I too am now wondering what a cam designed for this application would do. Hmmm....
Oh Yeah, I loved the results
With boost that thing is going to skoot...you need to be able to take out those KB and Whipple'd 4V's
, in which a 302 stroker is going to be hard to do and keep it a true street car. I think boost is the right direction, since you have the block and internals to handle it! I know you will get the good headgasket and tune with it all.The oil pump could be causing a little power loss, as you know
Yeah I remember Rick telling me that 331's and 347 dyno very similar.
I'd like a link to that TB thread, I didn't see it. You very well could gain something with the stroked combination you have and the power you make. Yeah, I have stated that if a real gain (back to back testing) is going to be shown on a throttle body, it will be in the topend of the spectrum
I'd like the track comparison, I run 10.56 at 99.31 mph (8.27 @ 87.31 mph in the 1/8th) in my car at a 'red-neck' track. You seem to pick up nicely in the top-end!
Grn - I predict 380rwhp - You ran 108 mph right with the 304? rwhp, and now you ran 115mph, so add 70-80. Get to a dyno.
