Pauls is in Michigan. Not to get into anything but I would stay away from there. Far Far Away!
Had my car to Paul's High Performance a couple of time. I would highly recommend them to anyone. Will be going back this winter for more work.
He's right, the IAC should be working under vacuum, not boost. That's proly why it wont idle. You shouldn't have it set up like stock intake there
If the manifolds/headers are getting bright red, you may have a timing issue is all I was implying but that issue should be preset 100% of the time.i didnt check the exhaust manifolds but everthing under the hood is red hot so id assume that the they are too....what are you getting at?
