stonecoldtx, your link show exactly what I'm referring to. The first picture shows the steering arm angle going towards the center of the rear axle. If that axle were to move, ie.. longer or shorter wheelbase, then the angle will still be pointing to that old spot, therefore, ankermann angle will have changed.
Also, I got a reply back from AJE Racing: Our K-member is only built to accept our a-arms or a custom built piece. We do sell everything seperately.
So . . . they indicated we could purchase just the K-member and their
control arms separately? If so, we could use the SN95 adapter and use those spindles.
Regarding the ackerman angle . . . again, if you place the spindle in exactly the same location (center of the wheelwell), there will be no difference in wheelbase.
Also, again, the components that control the ackerman angle besides the wheelbase are these items:
1.)
Steering gearbox, which controls the amount of travel available to manipulate the steering arms of the spindles
2.)
Hardware attached to the steering gearbox, because altering the length would ultimately alter much of the steering geometry
3.)
Length of the steering arms attached to the spindles--this is the most important thing. If those arms are the same length as what you are replacing,
AND you have placed the spindles in the center of the wheelwell (where they were before), the ackerman angle will remain the same.
Why? Simple--
if the ackerman angle is affected by the wheelbase (which it is, but it's not the *only* factor), and you
haven't altered that (by placing the spindle in the center of the wheelwell), then the only other components that
would affect it would be the items I have listed above.
If you look closely at the diagram, it shows that, when in a turn (which is when the ackerman angle comes into play), the third point of the triangle is *not* at the centerline of the rear axle--it is at the centerline of the turning radius.
Hope that clarifies that changing to a different spindle won't affect the ackerman angle so long as:
1.) The spindle is located in the center of the wheelwell (which maintains the same wheelbase)
2.) The steering arms on the spindle are the same length as the ones being replaced, and
3.) None of the other components have been changed (i.e.: steering gearbox, linkage, etc.).
