just remove the small bolt that holds each coil down and then the plugs are directly under the coils
On the trucks they do suck to get to. Number 4 and 8 is a bitch to get to.
peace
on the 2005+ 3v there is a TSB regarding this. The chances of removing the plug without breaking is greatly increased if 35 foot pounds is not exceeded during removal. In that case, spay pentrating oil and wait. Remove 1/4 turn, tighten 1/8 turn all the while not exceeding 35 foot pounds. Add a small amount of spray as it begins to come out.Be glad it's not a 5.4 3v. I've been changing the spark plugs on a friend's 05 F150 for 2 days now. They break apart in the head, and I've had to use a specialty tool to remove every single one of them so far.
Just watch when you are torquing the new plugs down to not angle the socket. It's very easy to crack the porcelain on the new plugs that way.
Dude its easy. Remember to blow out the plug wells like was said.
What plugs did you get?
The vehicle probably has platinums which Ford says will go 100,000 miles. Does this even need to be done?
Seriously, if you can't find plugs on an engine I'd seriously question the wisdom of turning wrenches on it once you find them... :|
Before you go and doubt my "wisdom" maybe you should check out my build thread'S (yes threads more then one) in 5.0 talk.
peace
what does a shop charge i wounder to do this? UGH this sounds like a job to tackle on a weekend day! I'm already haiting mod motors! And to think i was thinking of swapping a mod motor in place of my 360 in my 89 stangpeace
john![]()
I put new plugs in my Cobra this weekend, it was cake.
Installed some NGK TR6 @ .037 and its running great![]()
