it an 89 gt stock, i just replaced 4 injectors about 3 days ago, has new battery new wires and sparkplugs. it was working fine, i jes stoped to get a bite 2 eat n wen i was leaving it didnt want to turn on
pull the coil wire off the coil and check for spark first,,if there is spark spray some carb cleaner and see if she will try to start..no spark check power to coil...also u can depress the schrader valve on the injector rail to see if u have any pressure..(under cranking).......did it ever run at all? what happen .....run one day and not the other.../?
Most of the time when they just stop running like that it's the TFI module, if you're getting spark at the coil check spark at the cylinder, there is none thats a good place to start.
its been running for the past month n half n it just didnt want to start. it was working fine, just that it was like bogging so i replaced some of the injectors n it stop doing it but now it wont start
Can you hear the fuel pump running ? If not, suspect the fuel pump relay or maybe the fuel pump emergency shut off if it's been bumped or hit, maybe it needs to be reset.
thanks guys fo all ur help n information it was very helpful. it ended up been the tfi module. i had replaced it with a used on cuz i had broken it n i didnt know i had to put that cream, so it ended up giving out. once again thanks guys.
