- Jan 18, 2011
- 3
- 0
- 0
hi ppl i have a 94 mustang gt automatic, my transmission is kind of weak and im planning on getting a manual transmission, maybe a t-5. i have bbk headers on it and o/r h pipes, what exactly do i need for this converstion other than the tranny?
I have a 1996 ford must GT 4.6. I just installed a 5spd manual trans out of a 1996 mustang Saleen. My problem is now that I am finished the check engine light flashes and the Over Drive light flashes. The CPU is full of nothing but transmission codes! How do I fix this I have heard so many different options from just changing the CPU from an identical 96 5speed 4.6 to having to change the insterment cluster , key and CPU from a donor car that has the same set up that I now have. The car seems to run ok but this problem is driving me crazy. THANKS for your help! I can also be reached at [email protected]
if you do this, just make sure you know what you are doing. the guy who did mine screwed up the wiring changes and it burned up the tranny. then when i didn't want to take a chance on the first guy screwing something else up, i couldn't find anyone to touch it.Have you thought about a 4r70w swap?
