- Nov 21, 2011
- 71
- 0
- 7
car always cuts off from cold start after about 10 minutes hot/cold days, under load, wot, just sitting idle it doesn't matter
4 minutes later it will start and run normal with a small idle surge every couple of minutes
The only unfamiliar codes:
KOEO
14 Ignition profile pickup (PIP)
10 (a separator code I believe)
all maintenance is recent including a new summit racing distributor
hell today I cleaned the TB set factory timing and I even removed my cats in fear of a small clog still cut off after about 10 minutes... even if I cut it off before the 10 minutes it will start up normal and die on it's schedule
I
am
lost
any suggestions would be highly appreciated
KOEO
I
am
lost
