new to this whole thing so go easy on my please, ive tried everything I know to do , I have 89 notchback with a 347 stroker ,afr heads,victor intake , big ass cam, 36lb injectors ,255lph in tank fuel pump ,75mm throttle body ,76 mm between tb and maf , and believe my maf is 80 mm and ,all I know is the maf supposed to be the correct one for 36lb injectors. there is nothing stock on this motor I have the fuel pressure regulator sitting at about 40 psi ...PROBLEM---- I am running too rich the fumes are unbearable even at idle not really a lot of smoke alittle when I punch it , I have a Anderson for motorsport pms tuner , I have the fuel cut back 14% across the board and still running rich and if I go more than that its too lean , -14 will run and drive but still not running like it should and too rich ,my last thought was smaller injector and/or pump but everything im reading is similar setups to mine with no Anderson tuner and theres are running fine, please help before I go insane this car is broke me on expenses cant afford dyno right now and it kills me to just watch it sit .
